Boiler Components All Different Brands? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2010, 10:49 AM   #1
Rewards Points: 12
Boiler components all different brands?
So I went to start up and test my HW Baseboard heating system and realized that every integral part of the heater is a different brand. The damper is from Mizer, the control/pilot is from honeywell, and the boiler itself is Slantfin. The installation looks wonky (there's a big blue cylinder being supported by a 2x4 and the boiler is on bricks) so I figured I'd check.
Also, there was a leak the previous owner ignored and the pilot access panel is rusted up pretty good. If I take off the panel there's little/no rust inside of the boiler, so it's just cosmetic damage right?
jamieofansa is offline   Reply With Quote
Old 10-02-2010, 11:45 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
Hard to see it from here. Post a closeup pic. The parts all come from different suppliers and that is normal. The blue cylinder is an expansion tank. Recommend you get the whole system check by a Pro who does hydronic/hot water systems. Furnace guys don't all know them. Usually plumbers do. Slant fin is an economy boiler and I have heard that the burners can go bad on some and then you have the potential for CO poisoning.
Old 10-02-2010, 02:47 PM   #3
An old Tradesmen
Rewards Points: 7,278
Slantfin doesn't make their own boiler controls. or dampers. Most boiler manufacturers don't make their own controls or dampers.
Indoor Boiler Question AndrewF HVAC 134 05-13-2011 05:15 PM
Burnham boiler banging/thumping noises quadradeuce HVAC 6 10-02-2010 09:55 PM
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 06:28 PM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 08:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
