I have Weil-Mclain CG-4 88K BTU Boiler installed in 1994.
The T&P Guage has water dropplets forming on the inside of the glass - enough so it is hard to read the guages..this is actual water not fog.
I assume this guage is going bad so I need to change it - does anybody disagree?
MY boiler has an inlet shut-off valve but no return shut-off. IT also has an old style expansion tank.
I assume I have to drain the system to replace the Guage.. since I can't isolate the boiler from the rest of the system. I can isolate the expansion tank from the boiler. IS this Correct?
Tape should be fine. would not even touch the tank drain it replace the gauge refill, bleed it and you should be good to go. I always try to use OEM parts but if a generic will fit it should be ok
Before you go and drain the system down check the return and supply for shut off valve. Some installers will install valve so that you can isolate the boiler without draining the system and fighting air pockets later because and auto bleed doesn't work
I noticed that there is a nut right behind the guage that looks like it goes into the stem and then the step has a nut/fitting that goes into the boiler. Are these one in the same or can/should these pieces be seperated or replace the whole deal??
Also I am looking for an online source is there one that is well known?
Need to put system into a vacuum(the part that can be hard to explain when not there). And have the new guage sitting there ready to be changed instantly.
All things considered I only have the inlet shut off and/or the auto fill valve... so - what else is there?
If I close everything off, as soon as I pull the Guage or even lossen it, air will get in and water will come out... or will it take a minite or so before it starts coming out? What else is there?
Shut off the auto feed.
Close the valve between boiler and expansion tank.
Connect garden hose to boiler drain cock, and run the hose to a drain that is lower the the temp guage.
Have the new temp guage ready to install(threads already taped or thread dope on them).
Open boiler drain cock. Wait till water stops flowing(I usually loosen old guage slightly before opening boiler drain) boiler .
Quickly turn out temp guage and put new one in very quickly(I place new temp guage right infront of me while I do this).
As soon as you have the new guage turned in a thread or 2, close boiler drain.
If you do everything right. Less then 1 cubic foot of air will enter the boiler.
Then open all other valves that you closed.
If you have rads, run heat for a couple minutes, and then bleed rads.
PS: I would also drain the expansion tank after changing the temp guage. Hard to tell how much water it has in it, so its easier to drain it while your there. then clean up water in an hour or a day or 2.
Will water also be squirting out of the Guage connection? How long will it hold before it does? I do get it..
The water draining from below the guage will pull a vacumm - I guess it has to do with the drain flow from a lower point being greater than the drainage from the guage inlet. Is that kind of it?
You don't have much time. The longer the guage is out. The more air drawn into the boiler. And after so much, water can and will come out the guage port.
Old steam fitter/Yuri trick, and especially when doing galvanized pipe. Put teflon tape (good thick pink type) on first AND pipe dope on top of it. Guaranteed no leaks. Teflon tape is not foolproof and neither is dope when screwing into a fitting with water running out.
As you know the Guage is functioning properly except for the moisture/waterdroplets inside the glass cover.
I can turn/slide the glass around inside the Guage which means it is not sealed and then moisture is condensing inside. Is this ok & should I leave the whole thing alone since they are all this way? MAybe Put a little silicone around the edge of the glass to seal it or just forget about it?
Moisture always condenses on the coldest surface and has to come from somewhere. I have seen boilers for over 30 yrs and not seen water in a gauge. In theory there is no reason for moisture to condense inside it as it is the same temp as the boiler. Therefore it is possible that the bellows inside is leaking/starting to leak/may get worse. Not sure if it could rupture but it does not sound good to me. Post some pics of it.
That one is for Clover. He likes his bubbles/Labatts brewskies.:drink:
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
