Boiler Blowing Pressure Relief Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 08:06 AM   #1
Rewards Points: 150
Boiler blowing pressure relief valve
( this is a branch off of my orginal thread i think i posted in the wrong section, Baseboard Heat / Cold rooms / No Bleeders )
I had accidentally removed all the air from my expansion tank yesterday, then i started blowing the pressure relief valve @ 30 PSI.
In order to fix the problem, I removed the expansion tank from the system, drained all the water out. I then filled the expansion tank to 15 PSI then re-installed the tank onto the system.
Though now I am still blowing the pressure relief valve, Im starting out at about 18 or so PSI, then it gradually keeps building pressure as the system is running till it blows @ 30 PSI.
Any thoughts on what could be wrong?
alecmcmahon is offline   Reply With Quote
Old 10-18-2010, 05:52 PM   #2
An old Tradesmen
Rewards Points: 7,414
Turn off the manual valve tot eh auto water feed.
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 04:49 PM
Sewage smell from pressure relief valve drain daveh20 Plumbing 2 10-09-2009 10:45 AM
Vacuum relief valve? walker44 Plumbing 10 08-30-2009 04:33 PM
Kohler K-304 pressure balancing valve... EdTheDIYer Plumbing 0 05-12-2009 11:18 AM
too High boiler pressure beacu Plumbing 2 10-18-2008 11:52 AM
