boiler blowing off
hi i have a 5 year old peerless boiler that is blowing off the relief valve at 30 psi.
i have already replaced the water feed regulator to no avail . this system uses a super store indirect water heater with its own blow off valve.
the second blow off valve on the boiler keeps blowing off. i checked the schrader valve on the extrol model 30 P/n 9015a186 expansion tank, and have no water coming out. i reset the pre charge to 12 psi and tonight i noticed a small pinhole leak on the back underside of the tank near the water fill pipe. could this hole be my problem or should i look elsewhere. i know the tank needs to be replaced
