-   -   boiler blowing off (http://www.diychatroom.com/f17/boiler-blowing-off-32728/)
simba368 11-27-2008 07:51 PM
boiler blowing off
hi i have a 5 year old peerless boiler that is blowing off the relief valve at 30 psi.
i have already replaced the water feed regulator to no avail . this system uses a super store indirect water heater with its own blow off valve.
the second blow off valve on the boiler keeps blowing off. i checked the schrader valve on the extrol model 30 P/n 9015a186 expansion tank, and have no water coming out. i reset the pre charge to 12 psi and tonight i noticed a small pinhole leak on the back underside of the tank near the water fill pipe. could this hole be my problem or should i look elsewhere. i know the tank needs to be replaced
hvaclover 11-27-2008 08:46 PM
Please punctuate your post as it is all run together and makes no sense when i try to read it.
beenthere 11-28-2008 03:29 AM
Good chance its the tank causing the problem.
Bladder tanks can not be properly recharged while connected to the system.
Unless there is a shut off valve, and vent valve between it and the system.
simba368 11-28-2008 05:56 PM
boiler blowing off
hi just wanted to let you know i put a new tank in today works great thanks:thumbsup:
