Old 01-02-2013, 08:47 AM   #1
williamwallace's Avatar
Boiler ?
I live on the west coast. It does not get too cold here.
I have noticed that my home heat only manages to get to a bout 20 Celsius. My home has good insulation.
Not sure what's up with my heating system?
williamwallace is offline   Reply With Quote
Old 01-02-2013, 09:11 AM   #2
Boiler ?
me either.... more info required.... you should certainly get above 20C
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
williamwallace (01-02-2013)
Old 01-02-2013, 03:54 PM   #3
An old Tradesmen
Boiler ?
What temp is the boilers aquastat set to?
Old 01-02-2013, 04:18 PM   #4
Boiler ?
Looks like temps at about 140-150 .
Old 01-02-2013, 04:28 PM   #5
An old Tradesmen
Boiler ?
Set it to 160 or 170, and see if your house gets warmer.
Do you hear water moing when the heat is on. If so that is often an indication that air is in the system, which will reduce the amount of heat you get.
Old 01-02-2013, 05:12 PM   #6
Boiler ?
I blead the system, I heard a lot of gurgling.
Old 01-02-2013, 05:37 PM   #7
how
Boiler ?
Bleeding the air from the system if you had an air lock will help.
Your temp settings were also too low. Raising them should help.
How many zones/ thermostats do you have?
If you have baseboard radiators, check if the fins are dust clogged and limiting the air movement through them.
how is offline   Reply With Quote
Old 01-02-2013, 05:41 PM   #8
Boiler ?
Four zones, thanks ill try and raise temperature.
Sounds like I better call in some help from a plumber.
Old 01-02-2013, 08:22 PM   #9
Boiler ?
may be a wise idea...sounds like a little tlc will not hurt....
Suspect Electric boiler causing brownout crankcase Electrical 4 11-06-2012 02:41 AM
New Boiler for an Office - Got Two Quotes, but What Do We Need? Prolow Plumbing 0 09-17-2012 07:10 AM
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 12:37 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
