-   -   Boiler ? (http://www.diychatroom.com/f17/boiler-168016/)
williamwallace 01-02-2013 07:47 AM
Boiler ?
I live on the west coast. It does not get too cold here.
I have noticed that my home heat only manages to get to a bout 20 Celsius. My home has good insulation.
Not sure what's up with my heating system?
carmon 01-02-2013 08:11 AM
me either.... more info required.... you should certainly get above 20C
beenthere 01-02-2013 02:54 PM
What temp is the boilers aquastat set to?
williamwallace 01-02-2013 03:18 PM
Looks like temps at about 140-150 .
beenthere 01-02-2013 03:28 PM
Set it to 160 or 170, and see if your house gets warmer.
Do you hear water moing when the heat is on. If so that is often an indication that air is in the system, which will reduce the amount of heat you get.
williamwallace 01-02-2013 04:12 PM
I blead the system, I heard a lot of gurgling.
how 01-02-2013 04:37 PM
Bleeding the air from the system if you had an air lock will help.
Your temp settings were also too low. Raising them should help.
How many zones/ thermostats do you have?
If you have baseboard radiators, check if the fins are dust clogged and limiting the air movement through them.
williamwallace 01-02-2013 04:41 PM
Four zones, thanks ill try and raise temperature.
Sounds like I better call in some help from a plumber.
carmon 01-02-2013 07:22 PM
may be a wise idea...sounds like a little tlc will not hurt....
