Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 12:36 PM   #1
boiler
My boiler won't stop running- I have the temp set as low as it goes and it is almost 80 degrees in here. Help
Should buy a new thermostat? What is a 115 switch? All power is up and running fine- and we have had the heat on for over a week now and have not had any problems until this morning.
Last edited by united916; 10-30-2011 at 12:47 PM. Reason: added more info- questions
united916 is offline   Reply With Quote
Old 10-30-2011, 12:42 PM   #2
biggles's Avatar
shut the 115 switch off.... sorry like you didn't think of that relay might be failed closed...if the power is up and its running break the wire from the stat if it goes off the stat or the wire run is touching so your heat is calling...or pull the stat if it goes off the stat is messin' up....
Old 10-30-2011, 12:49 PM   #3
Not sure what a 115 switch is...the thermostat that we have hooked up to is it an older dial thermostat- with a mercury level inside of it. Should we replace this??
Old 10-30-2011, 12:56 PM   #4
biggles's Avatar
if your standing at the furnace it is the switch mounted on the side for service shutdowns....remove the stat from the wall the boiler should shut off..if it stay on go down to the boiler and disconnect one only thin stat wire either...and the boiler should shut down....if not on both the relay within is welded closed.....use the toggle on/off to control the house if your into a cold fall already
Old 10-30-2011, 05:26 PM   #5
how
Rewards Points: 1,104
If you don't have a power shut off on the side of your boiler....
The code for an electrical shut off for a boiler in my area is usually located between the boiler and the door to the boiler room.( Located higher than a normal light switch would be). If you can't find it, try the 15 amp service breaker that controls the boiler in your electical house service panel.
If the burners in the boiler continues to burn after the 120 Volt power has been turned off then there is a safety & boiler damage potential and you should immediately turn off the gas supply to the boiler.
I am also assuming that you only have one thermostat in the home for your boiler???
how is offline   Reply With Quote
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 11:37 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
Low water cutoff keeps shutting boiler off dolfish HVAC 7 12-06-2010 04:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Burnham boiler banging/thumping noises quadradeuce HVAC 6 10-02-2010 09:55 PM
