Board HK42FZ011 Led Rapid Flashing - HVAC - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 10:25 AM   #1
Board HK42FZ011 led rapid flashing
I have a carrier gas furnace and the led is continously rapid flashing and nothing works . ican some noice . please help me
dijas is offline   Reply With Quote
Old 10-11-2012, 10:56 AM   #2
Rewards Points: 508
Do some searches both within this site and using Google for "Carrier trouble codes" or "Carrier troubleshooting codes".
Some threads here that can start you off:
carrier furnace
Carrier 58SXC120 Furnace
Also search Youtube for helpful tutorials on troubleshooting furnaces.
Give furnace model also so pros can help.
diyorpay is offline   Reply With Quote
Old 10-11-2012, 11:05 AM   #3
how
Rewards Points: 1,104
Your furnace should have a diagnostic fault code legend inside the furnace. Usually on the furnace doors inside.
Try turning off the furnace power for a couple of minutes and then turning it back on and report back what the furnace does.
You mentioned some noice but gave no details?
how is offline   Reply With Quote
Old 10-11-2012, 11:07 AM   #4
Willing to listen
Rewards Points: 223
Agree with diyorpay...at least provide furnace model number. Also, usually a sticker is on the service panel detailing fault codes.
For some Carrier furnaces rapid flash is reversed line voltage polarity. Was this unit working up until recently?
Done That is offline   Reply With Quote
Old 10-11-2012, 11:51 AM   #5
my furnace model is 58mca60-12. the problem started with fan was contionously running. then i open the control board look for any sign .There was a burn spot and trace were broken. I repaired the trace and put it back
then I turned it on I heard some thing trying to get started and led flashing rapidly and after sometime now no flashing and every thing is dead.
Old 10-11-2012, 03:20 PM   #6
I checked the continuity of both limit switch both are fine. I already order a new control board. Is there anything else should I check before putting the new control board. thanks
Right now furnace is just dead
Both led lights on circuit board flashing on and off. ROBBYROPE HVAC 6 10-01-2012 04:58 PM
Replacing flashing at weatherhead mast daluu Roofing/Siding 4 08-05-2012 11:24 AM
Roof to Wall Flashing Installation Painted Cedar Lap Board Siding Deeppool Roofing/Siding 3 12-08-2010 07:36 AM
installing flashing around leaking chimmney made of hardy board texasblessedmom Roofing/Siding 12 10-18-2009 06:09 AM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 10:00 PM
