Blown Thermistor Model SG349 - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2013, 12:59 PM   #1
Blown thermistor model SG349
I have a carrier model 58mvp. The blower stopped working and I did a code check and got codes 41 & 44. After looking at some chats here I seen that it could be the thermistor. I have removed the blower and the motor
(GE CB02 09Cb ) no other makings on the motor. I looked at the thermistor and it is burned.
Here is where I am running into trouble I have a model SG349 and can not find a replacement, been looking on line for 2 hours.
is the a similar one that can be used?
I may not be correct on this but I think mine is 1 OHM/ 30 Amp but not 100% sure.
Any and all help to get this fixed will be greatly appreciated. It is suppose to get hot again middle of next week. I can take the heat more worried for my special needs dogs.
Mark
Mydogezra13 is offline   Reply With Quote
Old 09-06-2013, 02:44 PM   #2
Rewards Points: 77
Try Ametherm SL32 IR030 or Digi-key 570-1059-ND
firedawgsatx is offline   Reply With Quote
Old 09-06-2013, 04:43 PM   #3
Thanks!!!!!
Old 09-06-2013, 05:06 PM   #4
Rewards Points: 77
Like most everything electronic the price of the parts is small but the shipping is high for such a small item.
Old 09-06-2013, 07:32 PM   #5
Wasnt to bad. Thanks to everyone here i know i have the right part and will be cool soon
Old 09-07-2013, 02:23 AM   #6
I'm Your Huckleberry
Rewards Points: 2,270
An ecm motor and it's relation to it's components rely heavily on the totality of an hvac system's cordial intuitiveness to be able to perform.
Make damn skippy you have enough return air and that your evap coil is always pristine. Air flow or rather lack thereof took that motor/module/thermistor out.
Your system as an entity requires attention. Ecm's don't just fail for not reason.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
old_squid (09-07-2013)
Old 09-07-2013, 03:39 PM   #7
Thanks!!! Will make sure
Old 09-08-2013, 10:44 AM   #8
Rewards Points: 80
I bought this one from Newark dot com: Ametherm SL321R030. It was $2.70 and I believe they charged me a $1.00 or so for shipping.
FYI for future.
I got this item from this old post here:
http://www.diychatroom.com/f17/need-...tors-ecm-38270
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 09-08-2013, 08:38 PM   #9
FYI for future.
Thanks so much for the information it was a great help..... Need it fixed ASAP the dogs don't like it hot.....
Tags
carrier , sg349 , thermistor
Blown Insulation vs Blown Fiberglass DRILLINDK Insulation 7 12-18-2012 10:46 PM
batt insulation and blown in langless28 Insulation 14 11-06-2012 08:55 PM
Blown in insulation question? El Gringo Insulation 2 11-10-2011 11:20 PM
Spray Fiberglass, Blown in Blanket shazapple Insulation 0 09-06-2011 09:45 AM
Blown insulation Xtreme_99 General DIY Discussions 1 01-05-2009 05:56 AM
