Old 06-26-2010, 02:52 PM   #16
Moderator
blown in insulation
Air sealing an attic is seldom done properly and cellulose does help more than fiberglass in this regard (cellulose stops it, fiberglass filters it): http://bct.nrc.umass.edu/index.php/p...-smart-choice/
“Fiberglass is a suspected carcinogen and carries a hazard warning label. Cellulose is much more benign.” http://michaelbluejay.com/electricity/insulation.html
Cellulose is better in a fire, giving you more time to get out: http://www.cellulose.org/userdocs/Te...ectiveness.pdf
A good read: http://www.buildingscience.com/docum...rent-this-time
Be safe, Gary
Clothes taking longer to dry?
Old 06-26-2010, 05:10 PM   #17
Moderator
blown in insulation
My personal thoughts on fiberglass insulation:
it is not effective with air gaps between the insulation and the heat source---- http://oikos.com/esb/38/floorinsulation.html
it cannot have air washing against it from the cold side to negate the R-value: http://www.simplesavings.coop/simple...ee%20walls.pdf
it is stated: “Does inset stapling affect the R-value?
Inset stapling leaves a small triangular air space next to the stud and wall covering. Tests
have shown that the combination of the air space and the insulation beneath it provide the
same R-value as the rest of the fiber glass batt.” From-- http://www.insulating-products.com/p...lation_FAQ.pdf
Yet to me that sounds untrue. I reason with this and common sense about the convective loop and compression: http://oikos.com/library/insulating_...lls/index.html
No air gaps, no inset staples, no floor/ceiling gaps, but a perfect, professional installation harder for a DIY’er to achieve or a loss of product’s R-value: http://oikos.com/library/insulating_...lls/index.html
In an attic, fiberglass is a poor choice because it is exposed to outside air for roof venting. Add to that, air escaping from the heated living space below, the ice dams and other problems (mold) resulting from not air sealing, another insulation would be a better choice. Be sure to air seal the attic or you will just be filtering the moving air from below: http://www.rd.com/how-to-seal-attic-...icle18158.html Use extra thickness to counter the wind-washing effect present, even surpassing the cost/quality guidelines: http://www.enersavesystems.com/pdf/E...Insulation.pdf
Be safe, Gary
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
blown in insulation calculator? BlueBSH Building & Construction 1 04-27-2010 12:01 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 08:17 AM
Flat Roof and Blown Insulation... inlikeflint Building & Construction 4 01-26-2010 01:42 PM
Blown insulation Xtreme_99 General Discussion 1 01-05-2009 06:56 AM
