Blown Carrier Circuit Board - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 09:02 PM   #1
Blown carrier circuit board
I'm new & don't type well so please bear with me , My blower was not working had someone check that wasn't a tech but managed to hot wire motor to see if it worked , it did . so I called someone who service's hot water sys. & he thought it might be the circuit board but he doesn't know much about hvac . So he ordered new board , removed old & old board was burnt behind relay , changed bd. started furnace , still no blower . I switched the button on therm. to fan & the rest is history another $100 circuit bd for the trash . He is suppose to check with someone but I'm wondering if anyone has any thought's . I myself am a machinist & worked in engineering & am capable of using ohm meter's & I use to Drag race professianally & build motors but hvac is new to me . If anyone can point me in the right direction I would deeply appreciate it I can't afford another $100 bill out the window . Thank's
spoke69 is offline   Reply With Quote
Old 12-28-2012, 10:01 AM   #2
fuse
The new cicuit board had a fuse , just wondering why it didn't blow instead of frying the board behind the relay .
Old 12-28-2012, 12:42 PM   #3
HVAC Tech/Owner
Rewards Points: 604
The fuse is low voltage...not the 120 v to your board. What happened to the replacement board? I have a customer today that we hardwired the fan to run while I track down the proper board?
Technow is offline   Reply With Quote
The Following User Says Thank You to Technow For This Useful Post:
spoke69 (12-28-2012)
Old 12-28-2012, 01:44 PM   #4
An old Tradesmen
Rewards Points: 8,176
Good chance the blower motor has a short in its windings. The short may be in the winding for the fan only/cooling speed, but not the speed that your friend used to test the motor.
As above, that is a low voltage fuse, not a line voltage fuse.
The Following User Says Thank You to beenthere For This Useful Post:
Old 12-28-2012, 04:51 PM   #5
First off thank you for the reply , I have both bds. (1) pn# st9103a1036 Honey well was the orig. from carrier , the repl. bd w/ fuse is pn# hqr99g004 from Acme , both have burnt relay . Thanks for the info on the fuse the Tech @ Acme didn't tell me that . I do know that my friend that is a licensed plumber not Hvac did jump the orig to run the blower , however I didn't pay att. to what wire it was because I don't like someone looking over my shoulder while I work so I did the same for him . besides that he was doing me a favor . I understand the short maybe in the fan "only" circuit but why didn't it come on when the furnace was up to temp ? that was why I switched therm. to Fan only & the fire works began with the new circuit bd ?
Old 12-28-2012, 07:42 PM   #6
An old Tradesmen
Depends on how the motor is shorted. Might be almost a dead short on one speed tap, but not another.
goodman circuit board help melissamcclain HVAC 7 08-29-2011 06:20 PM
American Standard/ Trane Air Handler TWg048a140b1 -circuit board ?? gorillames HVAC 2 06-20-2011 10:10 AM
Need Bryant Plus 80 Circuit Board tbzep HVAC 3 12-30-2010 12:14 AM
Obsolete Air Handler Circuit board dvsrikanth HVAC 3 12-03-2010 01:01 PM
Goodman Circuit Board Shot - Can I Jury Rig Fan? ChrisInAtlanta HVAC 2 08-03-2008 02:54 PM
