Blown In Attic Insulation, Replace Or Add To - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-03-2008, 10:58 AM   #16
Here's a chart. I'm in zone two.
http://www1.eere.energy.gov/consumer...nsulation.html
but I used a chart from a DIY book.
Old 11-03-2008, 04:24 PM   #17
An old Tradesmen
Rewards Points: 8,236
It charts like that, that 10 years down the road, make people say I should have put more insulation in.
Those are based on current utility cost.
If the utility cost were 25% higher, they would recomend a higher insultation value.
How sure are you that your utility cost will be the same ten years down the road.
Old 11-10-2008, 08:25 AM   #18
I think it is more along these lines
http://en.wikipedia.org/wiki/Diminishing_returns
If the insulation and the elec. power were both free, you would still not get additional benefits from very thick insulation. The first inch of insulation you put in gives much more benefit than the last inch you put in.
I guess when your attic is adequately insulated you should look for the next largest source of heat loss. I think the attic typically accounts for only 25% of the total loss. Audel's has a pretty good set of books on this subject.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Attic Insulation Quote...what do you think? mitchel Roofing/Siding 15 08-06-2008 07:10 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Proper Attic Insulation reikiray Roofing/Siding 5 08-04-2007 10:59 AM
