Blown 3A Fuse In Control Board/HSI Mobile Home Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2014, 01:35 PM   #1
Rewards Points: 1,702
Blown 3A Fuse in Control Board/HSI Mobile Home Furnace
Coleman DGAT070BDD Mobile Home Natural Gas, with Integrated Control Board (with A/C Condenser outside). HSI Ignition, Combustion Air Motor (Booster Assy).
A/C compressor winding shorted to comp. case. Customer put a window unit in temporarily (mobile home) with hopes of new compressor in the spring.
Heat turned on for the first time today, since comp. shorted. Fuse is blown on control board. Could the comp. short have blown the 3A fuse on the control board. Haven't been to the job yet.
justplumducky is offline   Reply With Quote
Old 10-05-2014, 02:05 PM   #2
An old Tradesmen
Rewards Points: 7,816
Its possible that the transformer is grounded to the furnace frame. And the comp grounding took out the fuse. But not something that happens often.
The Following User Says Thank You to beenthere For This Useful Post:
justplumducky (10-05-2014)
Old 10-05-2014, 03:55 PM   #3
5 amp fuse ok?
Old 10-05-2014, 04:29 PM   #4
An old Tradesmen
3 would be better. 5 on't give protection from a slight over draw, but will against a dead short.
Old 10-05-2014, 04:59 PM   #5
OK, they got hold of a 3A, installed it and all is well so far, thx.
Old 10-05-2014, 05:08 PM   #6
An old Tradesmen
Glad to hear its working for them.
gas valve problem on Coleman 7663A mobile home furnace? appledude HVAC 10 03-08-2013 05:52 AM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
Miller mobile home oil furnace Msp1953 HVAC 15 02-03-2010 06:44 AM
Carrier Control Board Fuse Blows kdljet HVAC 5 03-11-2009 09:20 PM
Miller Mobile Home Oil Furnace jjalba9 HVAC 1 01-22-2007 10:57 AM
