Blowing Cold Air - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2008, 05:01 AM   #1
Question
Blowing cold air
Hello,
I hope someone can help me. I woke up this morning and the outside heat pump was running, but the inside handler was not. I turned it off at the thermostat. I waited and turned it back on and it started running, the temp. was set for 73 and the temp was reading 70, both units started running, after about 7 mins. the air handler stop, but heat pump was still running. I turned it off and on again same thing, but this time the air handler kept running. The heat on light in the t/stat was flashing, then aux heat displayed steady, but it is blowing cold air. While I was out yesterday, my wife told me the air handler was buzzing and she turned it off. I turned it back on and have not heard any noises. I know this is a lot, I just wanted to get it all in. The air handler is a Goodman AR-49-1.
TODD_70 is offline   Reply With Quote
Old 11-24-2008, 08:33 AM   #2
An old Tradesmen
Rewards Points: 6,476
Probably a bad sequencer in the air handler.
A/C not blowing cold air... rnorred13 HVAC 9 04-03-2014 04:03 AM
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 01:43 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
