Blower Works, But No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 05:14 PM   #1
blower works, but no heat
I have an 8 year old Nordyne indoor gas furnace connected to an outside ac/heatpump. The blower will run when I adjust the thermostat to heat, but it is blowing cold air. I have disconnected the pump. It has a dual fuel wiring setup. How do I get the thermostat to only recognize the furnace since the heat pump is now disconnected?
SLBarton is offline   Reply With Quote
Old 10-13-2012, 05:58 PM   #2
JJboy's Avatar
connect W from stat to W on furnace
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-13-2012, 06:19 PM   #3
Switch the thermostat to emergency heat.
Old 10-13-2012, 06:22 PM   #4
An old Tradesmen
Rewards Points: 7,372
If its wired up right. just set the stat to emergency heat.
Tempstar blower not coming on for heat robertsm HVAC 28 10-18-2012 04:13 PM
Help: Blower stuck, won't cool, won't heat, just cleaned jward HVAC 10 08-25-2012 09:45 PM
furnace doesn't heat but air conditioner works Jodi McFadden HVAC 10 03-26-2012 09:31 AM
how long for blower to run after heat call done? BlueBSH HVAC 1 01-17-2011 03:58 PM
Blower Works Once, then Quits Scottie T HVAC 3 02-05-2009 12:06 PM
