Old 06-28-2012, 11:18 PM   #1
Blower won't turn on with compressor
I had an hvac guy replace my fan limit and blower motor this past winter (blower died, switch was old). Furnace and blower worked fine after the work. Now my blower will not kick in when the A/C compressor is running. The thermostat will kick the compressor when the temp is set low so I believe that the hvac guy that did the work this winter mixed up the wiring- just a hunch, but the blower kicks fine when the furnace was going. Also- the blower will come on if I use the manual override switch on the fan limit.
I have attached a few (bad) pictures. Any help would be appreciated.
Blower won't turn on with compressor-imag0457.jpg   Blower won't turn on with compressor-imag0459.jpg   Blower won't turn on with compressor-imag0460.jpg   Blower won't turn on with compressor-imag0461.jpg   Blower won't turn on with compressor-imag0462.jpg
goodtimes is offline   Reply With Quote
Old 06-28-2012, 11:21 PM   #2
that is old stuff....... g from stat should power a relay or fan centre to bring blower motor on....
carmon is offline   Reply With Quote
Strange oil furnace problem: blower comes on before burner robparrott HVAC 6 12-12-2011 02:55 PM
3 phase 230/460 air compressor install questions DinAZ Electrical 7 10-21-2011 11:28 PM
Air conditioner compressor outside wont turn off.Why? Nicole1978 General Discussion 1 12-03-2010 07:39 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 05:00 PM
blower motor won't turn on blanker HVAC 7 10-03-2008 05:01 PM
