blower won't turn on in AUTO
if you open the blower compartment, you'll see what appears to be like you said, a big computer chip, follow your t-stat wire and it'll lead you right to it (inside the unit) it'll either be a dark brown, polished black, or pale white board, on the board you'll see your t-stat connections as well as about 15 other larger wire connections, that's your board. However, if your unit is older, you'll have what looks like a transformer with about 12-15 metal pegs sticking out of it, that is your fan relay DO NOT TOUCH IT without making certain the power is off at the breaker and service disconnect. If it's not a board, it's a relay, a board will show subtle signs of burn or capactior breakage in the back of the board, you'll need a new one. A relay is about 15 bucks from any supplier, if you have one, probably wouldn't be a bad idea to replace it either way
