Blower Wont Start - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 02:48 PM   #1
blower wont start
I have a 5 year old Heil heat pump {only in use three years}. out side fan and compressor come on and produce heat. blower has a GE ECM X-13 direct drive motor. On startup the motor starts rocking or pulsing {moving} but dosn't ever start to rotate. I checked voltage on L1 & L2 120 volts on each.
Speed control set in #2 slot has 24 volts. The furnace has two electric heating elements for emergencies. Thermostat seems fine. This just started.
I replaced the transformer, wasnt geting 24 volts out.
Brian Hartley is offline   Reply With Quote
Old 12-11-2012, 03:52 PM   #2
Rewards Points: 14,312
Bad Capacitor most likly.
That's what give the motor a kick in the butt to get turning.
Old 12-11-2012, 09:47 PM   #3
Experienced HVAC Tech
HVAC1000's Avatar
I agree bad capacitor. Make sure you change it out with same MCF. If that does nothing you've got yourself a bad Blower Motor
HVAC1000 is offline   Reply With Quote
Old 12-12-2012, 05:12 AM   #4
An old Tradesmen
Rewards Points: 8,228
X13 doesn't use a capacitor.
Check to make sure you read 240 volts+/- across L1 and L2.
If the motor is bad, that would point to very restrictive duct system, or moisture got inside it.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (12-13-2012)
Old 12-12-2012, 12:34 PM   #5
blower wont run
I have 240 volts +/- at motor. furnace is in attic and I found upper accces plug missing in the evap. panel, just below and to the backside of motor. could that affect the motor over time. I change the air filter regularly. air flow was good when working. thanks for your help. the motor spins freely by hand and tries to start, pulsing and rocking.
Old 12-12-2012, 02:59 PM   #6
An old Tradesmen
If moisture got to it from the pan it could harm the motor.
Post model number of the air handler. Some brands did have a problem with X13 motors.
Old 12-13-2012, 12:56 PM   #7
blower motor inop
HEIL Heat pump, model # FEM2X, the blower sits above coil {updraft}.
Old 12-13-2012, 01:09 PM   #8
Items wanted: Time
Rewards Points: 150
I believe that would make it a downflow.
NiNe O is offline   Reply With Quote
Old 12-13-2012, 04:09 PM   #9
An old Tradesmen
Blower above coil would be upflow.
Heil/ICP is one of the brands that had some problems with X13s. Heil is owned by Carrier.
Contact your local distributor or dealer.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (12-13-2012), Brian Hartley (12-14-2012)
Old 12-14-2012, 05:28 AM   #10
Items wanted: Time
Rewards Points: 150
S o a b, don't see many pull throughs.
Old 12-14-2012, 05:30 AM   #11
An old Tradesmen
Here its the norm. So that the heat pump and strip heat can run at the same time.
Old 12-14-2012, 05:33 AM   #12
Items wanted: Time
Rewards Points: 150
Ahh, here, .1% of homes have a heat pump.
Old 12-14-2012, 02:55 PM   #13
An old Tradesmen
Yeah, your area is a bit colder and for longer then mine.
blower problems with bryant furnace. blowerissue HVAC 4 03-13-2012 11:34 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
Blower NOT continuously ON on Bryant 310AAV rational HVAC 5 08-15-2011 08:44 PM
Lennox G20 Series - Bad blower board - or is it more? inn8pwr HVAC 48 12-30-2009 04:13 PM
