Blower Won't Start... - HVAC - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 07:49 PM   #1
Blower won't start...
I'm sure there has been several discussions on the very same topic, but I havent really found the exact same issue. Anyway here's what's happening. Thanks in advance for any help.
Turned on ac, condenser & compressor start up fine. Blower has a drum like sound and its trying to start but cant, I've hand spun the cage and threw power on and 50% of the time it catches.
ANY HELP is greatly apprieciated.
DWN3GRN is offline   Reply With Quote
Old 06-24-2012, 07:53 PM   #2
JJboy's Avatar
Model???? Serial????? Is this ECM blower motor?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-24-2012, 07:58 PM   #3
Originally Posted by jjboy View Post
model???? Serial????? Is this ecm blower motor?
RHEEM CLASSIC PLUS
model: Rhla-hm4821ja ser# m4807 03019
x13 motor
Old 06-24-2012, 08:19 PM   #4
JJboy's Avatar
http://www.google.com/url?sa=t&rct=j...wKZyBy_wicNDnw
http://www.google.com/url?sa=t&rct=j...8w_klFc9oZH1-g
Old 06-24-2012, 08:29 PM   #5
Thanks JJ, Ive read this whole manual. All volts are good.. I wanted to know where the run and start caps are? (So, if i can hand start it, does the run cap need replacing too?0=)
Old 06-24-2012, 08:50 PM   #6
AKA HVACTECHFW
Rewards Points: 1,208
there are no capacitors for X-13 motors
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-24-2012, 08:53 PM   #7
Hi hvactech,
I guess thats why i couldn't locate em. lol There is a relay that is in the upper left corner. Would this relay not open/close to start the blower?
Old 06-24-2012, 08:56 PM   #8
AKA HVACTECHFW
Picture? I have no idea what relay you are talking about.
IT IS WHAT IT IS
Old 06-24-2012, 09:01 PM   #9
Just got the blower to catch, its blowing high speed then degrades to low then back to high and so on.
Old 06-24-2012, 09:05 PM   #10
AKA HVACTECHFW
sounds like a bad motor or controller. need to check voltages to the motor and which taps are active in order to determine for sure. Use the manuals posted earlier to diagnose.
IT IS WHAT IT IS
Old 06-24-2012, 09:10 PM   #11
JJboy's Avatar
This blower motor works this way by varying the speed.
Old 06-24-2012, 09:12 PM   #12
AKA HVACTECHFW
this blower motor works this way by varying the speed.
nope!
IT IS WHAT IT IS
Old 06-24-2012, 09:13 PM   #13
I will check the volts again. Thanks guys. I did put my hand over the motor and its cool, so its not overheating.
Old 06-24-2012, 09:20 PM   #14
JJboy's Avatar
nope!
Are you saying that speed does not vary?
Old 06-24-2012, 09:23 PM   #15
I believe the V/speed is when switching to Heat. Heat = LOW
blower problems with bryant furnace. blowerissue HVAC 4 03-13-2012 11:34 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
Blower NOT continuously ON on Bryant 310AAV rational HVAC 5 08-15-2011 08:44 PM
Lennox G20 Series - Bad blower board - or is it more? inn8pwr HVAC 48 12-30-2009 04:13 PM
