Blower Won't Shut Off On New Gas Furnace - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-06-2009, 10:31 PM   #31
GC/Master Plumber/Mech
Rewards Points: 560
Just remember to test the it. I told you how earier. Also you can use an ohm meter and check the SLA to see if it is closed or open. It needs to be closed
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-07-2009, 10:53 AM   #32
JohnH1's Avatar
Originally Posted by johnny67 View Post
I can't figure this out. I have a 2year old gas furnace. The blower won't turn off and I can't find a switch on the furnace like my old one had that can keep the blower always on or off. The only switch is for the lower cover that shuts it off. I am not familiar with this furnace because it is a house that I rent to tenants. I tried an old school t stat and a new digital one with the same results. There are only 2 wires coming from the circuit board right now. The only time it shut off was when I raised the heat and then it turned on again and stayed on. The heat works fine. Is there a switch that I am not seeing on the furnace?
Am I missing something here? He said the heat worked fine if the limit was bad the heat / burners would not operate.
JohnH1 is offline   Reply With Quote
Old 09-08-2009, 12:42 AM   #33
I checked the 2 limit switches and tried to push in the button but they seemed to be fine and would not push in. I then took the 2 blue wires off of the SAL and connected them together and the fan would still not turn off. I also let the furnace run through a heating cycle and the fan did not turn off after it got to the set temperature.
Is there any other test I can do to figure this one out?
johnny67 is offline   Reply With Quote
Old 09-08-2009, 02:45 AM   #34
Look at the photo on #16. The two blocks on the right, both of those blocks is a relay that will energize the fan. While the unit isn't in heating mode & fan is still running, tap each relay with a screwdriver handle. It sounds as if you have a sticking relay. If the fan quits, it's likely that relay is the culprit, and the board should be changed. If the appliance is only 2 years, it's probably covered under a warranty.
Unit should not go into heat mode if there was an open limit switch.
Flashheatingand is offline   Reply With Quote
Old 09-08-2009, 03:13 AM   #35
Hey, on second thought, you should turn the line voltage to the furnace off, then tap on the relays.
Old 09-08-2009, 06:09 AM   #36
ok I will try that. I did tap on them when the fan was on but I will try with the furnace off.
I will also dig out my reciept for the furnace and see if I still have a warranty.
would it help if I installed the old style T-stat to eliminate the variable of a malfunctioning digital T-stat?
Old 09-14-2009, 09:23 PM   #37
Today the I had the original furnace installer to come check it out. He found a jumper wire was installed by my ex tenant to keep the fan on all the time. The good part is I was not charged a service call fee (he has a dedicated customer now). I guess if I had posted a better picture one of you guys would have spotted that extra wire. Thanks for all the help.
How much power does a small furnace blower use? Red Squirrel HVAC 10 07-31-2009 09:03 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
Newmac furnace blower won't shut off dsgreer HVAC 2 11-03-2008 01:23 PM
Oil furnace won't shut off tef HVAC 3 11-13-2007 08:43 PM
