Blower Won't Shut Off On New Gas Furnace - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-06-2009, 07:15 PM   #16
Originally Posted by Plumber101 View Post
Check the limits that are on the blue wire. There is one right up front and one that is by the blower. They should be closed circuit. They also had a manual reset. The button in the middle of the connector. Just a thought to see if one has tripped.
How do you check the limits of the blue wire? I have not seen the manual reset. Where should I look?
johnny67 is offline   Reply With Quote
Old 09-06-2009, 07:25 PM   #17
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
I thought that was odd. All that's used in my area is copper gas lines.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 09-06-2009, 07:39 PM   #18
GC/Master Plumber/Mech
Rewards Points: 560
Open the link and look at the limit.
There is a blue tab (Yours may not have the blue) But the tab that sticks up you will push in to reset the limit
http://americanhvacparts.com/Merchan...Code=fl-tdl-ro
This is just a hunch....
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-06-2009, 07:50 PM   #19
where about is this limit located?
Old 09-06-2009, 08:04 PM   #20
Rewards Points: 560
Follow the BLUE wires, Start at the control board.
I think there are 2 or 3
One can be seen just in front of the flue pipe
Old 09-06-2009, 08:06 PM   #21
JohnH1's Avatar
Originally Posted by beenthere View Post
Natural gas, and copper are fine together.
Its the acid that some of the companies don't remove that is a problem.
Some areas certify their gas to be acid free.
His may be one of those areas.
I did not know that. Learned something new Thanks
JohnH1 is offline   Reply With Quote
Old 09-06-2009, 08:18 PM   #22
An old Tradesmen
Rewards Points: 7,826
No problem.
Old 09-06-2009, 08:46 PM   #23
Rewards Points: 560
Can you check to see when the blower is running all the time do you get a flash code on the control board?
Old 09-06-2009, 08:50 PM   #24
I see in the picture 2 blue wires going up to the right hand corner of the furnace and attatching to a switch that looks like the one you had in your link. There looks to be a red tab there, I will try to push it in and reset it tomorrow when I am at the house. Would the other limit switch be behind the lower panel of the furnace?
There is a red light that is lit on the board but it is not flashing any codes that I could tell.
Old 09-06-2009, 09:38 PM   #25
Rewards Points: 560
No, it looks like it is around the burners.
I went to Nordyne site and was reading the install manual. If none of the limits are tripped then I would replace the supply air limit. Right behind the gas valve. To verify that this limit is bad, disconnect power to the furnace. Remove the two wires off the limit and connect the two ends together, then restore power to the furnace and see if the blower stops running
It says in the manual that if the supply air limit is run longer that 4 minutes with a very restricted return air that it can damage the SAL.
Depending on how dirty the filter was, and it would have to be pretty dirty, this could damage it limit
Old 09-06-2009, 09:44 PM   #26
Customer service/Goodman
Limit Switch
Originally Posted by johnny67 View Post
I can't figure this out. I have a 2year old gas furnace. The blower won't turn off and I can't find a switch on the furnace like my old one had that can keep the blower always on or off. The only switch is for the lower cover that shuts it off. I am not familiar with this furnace because it is a house that I rent to tenants. I tried an old school t stat and a new digital one with the same results. There are only 2 wires coming from the circuit board right now. The only time it shut off was when I raised the heat and then it turned on again and stayed on. The heat works fine. Is there a switch that I am not seeing on the furnace?
Call a Qualify Service Tec the Limit Switch is bad!
Customerservice is offline   Reply With Quote
Old 09-06-2009, 09:50 PM   #27
Rewards Points: 560
Simple to do.
You can buy the part online..
Two screws, two wires...
Too simple
Old 09-06-2009, 09:59 PM   #28
Okay I will check the 2 limit switches to see if I can push them back in then I will check the Sal switch by the gas valve. Is the SAL the one with the yellow and brown wire going to it?
Old 09-06-2009, 10:20 PM   #29
Rewards Points: 560
Pic of one
Link to manual
http://www.nordyne.com/literature/7085020.pdf
Link to parts manual
http://www.nordyne.com/literature/7087000.pdf
I think the part number you need is 626418
Link to where you can buy...About $15
http://www.mobilehomerepair.com/NordyneGas.html
Old 09-06-2009, 10:26 PM   #30
thanks alot for all the great info. this is a great web site for the DIYer
How much power does a small furnace blower use? Red Squirrel HVAC 10 07-31-2009 09:03 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
Newmac furnace blower won't shut off dsgreer HVAC 2 11-03-2008 01:23 PM
Oil furnace won't shut off tef HVAC 3 11-13-2007 08:43 PM
