Old 01-10-2009, 05:06 PM   #1
Blower will not shut off
I have a Bryant Furnace Model #310AAV0360AAJA and the blower will stay on 24/7. I adjusted the thermastat and replaced it with a new one today. I replaced the filter too. Does anyone have a sugestion of what I can do myself before I call in someone to look at it?
Rick Copes is offline   Reply With Quote
Old 01-10-2009, 05:52 PM   #2
the Musigician
DangerMouse's Avatar
be sure on the thermostat it's set to "auto", not "on"?
check for similar switch on/in furnace too.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-10-2009, 06:29 PM   #3
Electrician
DM
I agree, the Fan switch is probably set to ON, either at the furnace or the tstat, if NOT, then you have a short between "G" and "R" terminals.
chris75 is offline   Reply With Quote
Old 01-10-2009, 06:57 PM   #4
HvacWiz's Avatar
Is this a gas or electric furnace? If its gas you have a limit switch open, if its electric your fan reley is sticking.
HvacWiz is offline   Reply With Quote
Old 01-10-2009, 09:35 PM   #5
Have replaced a lot of blower boards on that model for the same issue. Could be your problem.
SKIP4661 is offline   Reply With Quote
Old 01-10-2009, 11:00 PM   #6
hvaclover's Avatar
Bad model number...won't cross in data base.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Blower will not shut off. lj4 HVAC 14 12-11-2011 03:16 AM
Replaced blower motor in 58MVP now it wont shut off robr1 HVAC 4 12-19-2008 07:21 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 10:08 PM
Newmac furnace blower won't shut off dsgreer HVAC 2 11-03-2008 02:23 PM
