Blower Will Not Run - HVAC - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 02:26 PM   #1
blower will not run
i have an intertherm model MGHA furnace in a mobile home.the burner ignites but the blower will not kick on. blowe will work if switched to fan from auto setting so motor is ok
maggieblue is offline   Reply With Quote
Old 01-29-2011, 02:36 PM   #2
HvacWiz's Avatar
Rewards Points: 252
Is there a circuit board on your furnace? If so that also controls the fan on a timer. probaly needs replaced.
HvacWiz is offline   Reply With Quote
Old 01-30-2011, 06:22 PM   #3
Licensed Engineer
Rewards Points: 171
Or bonnet switch has failed. The thermostat turns on the gas burner, a temperature increase in the bonnet (or heat exchanger) activates a thermal switch that turns on the blower.
MI-Roger is offline   Reply With Quote
Old 01-30-2011, 11:06 PM   #4
Originally Posted by maggieblue View Post
i have an intertherm model mgha furnace in a mobile home.the burner ignites but the blower will not kick on. Blowe will work if switched to fan from auto setting so motor is ok
all modern furaces time the blower on delay,they rarely,if never use temp anymore .replace the control board and youll be fine
DELTA.T4935 is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 05:48 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 05:00 PM
