Blower Will Not Cycle Off - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2008, 01:05 PM   #1
blower will not cycle off
I have a Heil natural gas heater (p/n NUGK100DH03) The blower will not cycle off. The termistat is in the auto mode. I have a feeling it is either the main limit or the fan relay. Can some one let me know how I can tell??
spmllc is offline   Reply With Quote
Old 02-23-2008, 02:43 PM   #2
Blower Runs
Hi it can be a number of things but more than likely you are on right path with a limit switch either can be one of the rollouts with are normally located near the burners and have the red resets or it is the main limit which is above the burners is a little square with 2 screws holding it into the heat exchanger section easiest thing to do is first check manual resets on the rollouts then take a multimeter and check ohms or shut power off pull the wires off each side and check for continuity remember the switch is in the closed position it opens on safety also check your air filter !
Boilerman20 is offline   Reply With Quote
Old 02-23-2008, 04:22 PM   #3
Does your limit switch resemble these?
If you remove the cover and slightly rotate the dial you should hear where the limit switches are "click" on or off.
You could try to the spray the limits with contact cleaner but if the unit is older then it may be best just to replace the unit as they wear out.
redline is offline   Reply With Quote
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 06:41 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Trane xl90 Combustion blower Issues bjpaff HVAC 3 12-18-2007 10:00 PM
Blower control board mlmaher HVAC 1 11-24-2007 01:39 PM
Goodman HVAC gmp100-3 Inside blower problems ray_adrea HVAC 4 06-28-2007 12:31 PM
