Blower Wheel Vibration - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 09:33 PM   #1
Blower wheel vibration
Is there anyway to balance a blower wheel inside a squirrel cage? I recently cleaned my squirrel cage, when I put it back together I notice the blower wheel is out of balance. It does not hit the side of the squirrel cage, however the unit is vibrating worse since I cleaned the wheel. I am thinking I might have damage the blower wheel when I was pulling it off the fan shaft. I am afriad if I keep running it, that it will ruin the bearings in the motor. The other possibility could the shaft on the motor cause the vibration? I was hoping I could try and balance the wheel, before I purchase I new one. If not how can i tell if the squirrel cage is out of balance? Or if it's the shaft in the fan motor. There is no physical damage to either the fan or the cage. Thanks for the help
Knipper64 is offline   Reply With Quote
Old 11-10-2011, 09:38 PM   #2
Rewards Points: 582
maybe while you were cleaning you knocked of some of the weights ..i never tried to balance .seem like would be tough....new blower wheels are cheap If it were mine i would just change wheel....seems like that would eaiser,...Ben....make sure you have your reinstall after cleaning right ..double check...alignment
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Acceptable Blower Vibration John_NH HVAC 15 11-21-2010 01:49 PM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 05:48 AM
comfortmaker rpj2 blower wheel problems nuclearjesus HVAC 3 11-22-2009 09:14 PM
Need inducer blower wheel sonnygentry HVAC 3 01-05-2008 01:12 PM
