Blower Troubles - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 04:41 PM   #1
Blower Troubles
I have a carrier forced air heating system. My system will start up, then the blower will blow warm air for about five minutes and then stop. It will cycle on and off for about 15 minutes and then stop all together.
There have been a couple days where it ran beautifully without troubles.
Last night it wouldn't work again and while I was messing with it I noticed the hot water heater kept running. Nothing was using water at the time.
Last year the blower gave me problems and I kept having to reset "something" to make it work again. I had that manual switch replaced with an automatic one and that was the end of the trouble last year.
I'm a single mom with not a lot of hvac knowledge. Although I'm learning.
My filters are fine.
Is there something I can check on my own or should I go ahead and phone a repair person?
MsAngeliaS is offline   Reply With Quote
Old 01-04-2011, 04:56 PM   #2
Sounds like a fan relay or a bad fan moter.Try putting the fan in on position.This should select the high speed. Heat is usually a low to medium speed.
semore 102 is offline   Reply With Quote
Old 01-04-2011, 04:57 PM   #3
Blower Troubles
Thank you I'll try that tonight and post the results tomorrow.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Blower troubles ron67 HVAC 1 02-09-2010 04:47 PM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
