Blower Stays On? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 06:05 AM   #1
blower stays on?
my blower in my Totaline programmable t-stat stays on. any quick ideas before i call in for major repair?thermos
mrfmurphy is offline   Reply With Quote
Old 04-19-2011, 06:09 AM   #2
the Musigician
DangerMouse's Avatar
Is the switch on the T-stat set to "auto"?
DM
Old 04-19-2011, 05:26 PM   #3
auto
i have tried both auto and off
Old 04-19-2011, 08:47 PM   #4
Rewards Points: 150
A quick idea? Since your fan switch is set to auto, If you have a gas furnace, there is sometimes a push/pull button on the fan control which will cause the fan to run continuously. If you're mechanically inclined, I can post other ideas.
Mark
rightit is offline   Reply With Quote
Old 04-20-2011, 04:54 PM   #5
thanks. i am not mechanically inclined, but if you could tell me where i might find the push/pull button that would help.thanks again
Old 04-21-2011, 12:49 AM   #6
I'm Your Huckleberry
Rewards Points: 2,270
well then it's safe to tell you that a stat does not have a blower inside of it.
If this is a new install of the stat, which I'm guessing it might be, then it could be that 24 volts is being sent to the fan constantly which would suggest that the red wire in the stat is on the g in the stat.
Doc Holliday is offline   Reply With Quote
Tags
always on , blower fan , hvac , totaline
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Carrier 58RAV Blower Stays On Error 33 btweazel HVAC 5 11-29-2010 09:31 AM
blower fan stays on at all times d3970 HVAC 3 06-07-2010 07:00 PM
furnace blower stays on jay53 HVAC 2 04-21-2010 05:56 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
