Old 08-27-2010, 03:34 PM   #1
Question
Blower squirrel cage
Hello Hvac pro
I just want to know where is the blower fan squirrel cage in Armstrong furnace?
Which panel to remove, ?when I open door I can see the filter and behind it is the evaporator coil rectangle shape ,above it is the circuit board and capacitors and transformer. Where is fan blower ? It can't be behind coil .would you know which panel to remove ,I just want to clean and inspect the dirt in that cage .
Dbenzboy is offline   Reply With Quote
Old 08-27-2010, 03:57 PM   #2
Originally Posted by Dbenzboy View Post
Hello Hvac pro
my guess it is behind a panel above the A coil . Most likey a panel above or on the Cooling Plenum It has to be above the coil to move the air across for cooling . Take a pallel off ?
del schisler is offline   Reply With Quote
Old 08-27-2010, 06:08 PM   #3
There is no door panel to remove it.in order to remove the top panel ,I have to unscrew the door panel of burner and take the whole panel out but looks like it won't come out .is anyone taken this panel out before?it's kind a wrap around the frame
Old 08-27-2010, 07:08 PM   #4
An old Tradesmen
Post a pic of the unit.
Old 08-27-2010, 09:05 PM   #5
Call the company they will tell you . I guess it is not like most unit's
Bryant Plus 90 - No Blower Ducaticorse HVAC 11 10-16-2012 09:39 PM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Blower fan woes.... overland47 HVAC 1 11-23-2009 09:00 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
Squirrel cage motor in air handler...no start andyinrichmond HVAC 13 03-15-2009 04:53 PM
