-   -   Blower squirrel cage (http://www.diychatroom.com/f17/blower-squirrel-cage-79837/)
Dbenzboy 08-27-2010 02:34 PM
Hello Hvac pro
I just want to know where is the blower fan squirrel cage in Armstrong furnace?
Which panel to remove, ?when I open door I can see the filter and behind it is the evaporator coil rectangle shape ,above it is the circuit board and capacitors and transformer. Where is fan blower ? It can't be behind coil .would you know which panel to remove ,I just want to clean and inspect the dirt in that cage .
Thanks:eek:
del schisler 08-27-2010 02:57 PM
Originally Posted by Dbenzboy (Post 492100)
Hello Hvac pro
Thanks:eek:
my guess it is behind a panel above the A coil . Most likey a panel above or on the Cooling Plenum It has to be above the coil to move the air across for cooling . Take a pallel off ?
Dbenzboy 08-27-2010 05:08 PM
There is no door panel to remove it.in order to remove the top panel ,I have to unscrew the door panel of burner and take the whole panel out but looks like it won't come out .is anyone taken this panel out before?it's kind a wrap around the frame
beenthere 08-27-2010 06:08 PM
Post a pic of the unit.
del schisler 08-27-2010 08:05 PM
Call the company they will tell you . I guess it is not like most unit's
