Blower Shuts Off Even When Set To 'on' - HVAC - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 03:07 AM   #1
Always learning...
fetzer85's Avatar
Rewards Points: 262
Blower shuts off even when set to 'on'
I've searched and read through numerous other posts however I haven't been able to find anything exactly like my problem.
We recently moved and the furnace and central a/c are both very old. Furnace is probably 30+yrs and a/c is probably 15+yrs, however they both 'seemed' to work ok. The furnace got us through this winter, with the exception of the blower motor failing in early March. A local place came out and replaced it with a used motor and things continued working just fine.
This April I tried using the a/c for the first time and it kicked on fine, but I noticed about 15min later the blower wasn't on anymore, but the a/c was still running outside. I could see frost on the line outside and I quickly learned that the coil freezes up when the blower isn't running. I tested it out several more times and each time it would start running but then shut off within an hour or so. This led me to believe there was some problem with the system not realizing that the temperature hadn't yet reached our set temperature (so maybe it was still 76 degrees in the house and I had it set to 72) and so it was telling the blower to shut off.
I then tried running it with the fan set to 'on'. The blower always turns on however it shuts off at totally random times thereafter. Sometimes it only runs for 5 or 10min, and other times like just a few days ago, the blower ran continuously for about 3 days straight. I'm sure its just irony, but it seems like it shuts off more frequently on hot days and then says 'Oh hey I can run for you' on the not-too-hot days.
So, with that said, what would your recommendations be on my problem? Despite the age of the system, when the blower decides to run, the a/c can manage to keep the first floor of our house comfortable even when temps climb into the 90's, so if we can salvage another year or two out of the extremely dated system then that would be great. The easy but potentially expensive option is to call a technician - I am willing to do some tests or maybe even clean the blower out if it could potentially solve the problem.
Thanks to anyone who has some useful input.
fetzer85 is offline   Reply With Quote
Old 07-05-2010, 11:48 AM   #2
Could be low on freon. Check and clean indoor evap coil if it's dirty. Check your blower cap. Check and clean the blower squirrel cage if it's dirty. Also check your used blower motor.
max2k is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Furnace Shuts down B4 Blower motor engages Kooks from Michigan HVAC 5 03-18-2011 12:11 PM
Trane XV 90 shuts off burner and exaust blower zootjeff HVAC 0 12-01-2009 11:50 PM
Furnace Shuts down B4 Blower motor engages Kooks from Michigan HVAC 1 02-23-2008 12:52 PM
blower shuts off in auto after 5 secounds Kevin MacAllister HVAC 1 02-03-2007 11:41 AM
