Blower Shuting Off - White Rodgers 50A50-241 - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 10:56 PM   #1
Blower shuting off - White Rodgers 50A50-241
I have a White Rodgers 50A50-241.
When heat is called for, blower turns on, ignitor turns on and blower runs for a couple of minutes.
Blower then shuts off. The red light blinks 4 times. I notice a faint burnt smell from the vents.
Anything I can try? Any suggestions...
Brr! Thank you...
hemanth12 is offline   Reply With Quote
Old 02-06-2011, 10:58 PM   #2
HVAC / Plumbing
look on back of the blower door & find the code. I guess you are talking about the vent motor & not the blower motor. Blower motor may not be comming on & the unit is shutting doun on high limit. If this is the case you might check the capicator on the blower motor
kenmac is offline   Reply With Quote
Old 02-07-2011, 07:48 PM   #3
It's the vent motor. Sorry Kenmac, my bad...
When the blower turns on, it runs very slow. I can barely get an air from the vents.
Anything I need to check?
Old 02-07-2011, 07:52 PM   #4
HVAC / Plumbing
Check / replace your return air filter, Motor could be going bad . Check capicator as well. When you say blower. I'm thinking blower motor & not exhaust vent motor
Old 02-08-2011, 12:05 PM   #5
Confirmed capacitor is the culprit . MM shows it's shorted.
BTW, it's 97F9002.
Hope this didn't fuse the motor. Will replace cap and post.
Air filter is good...
Old 02-08-2011, 03:49 PM   #6
Just replaced. Works like a charm!
4 flashing Red lights on White Rodgers 50A50-241
Slow rotating fan
Probable cause - Capacitor
Thank you Kenmac!
Tags
4 blinks , 50a50 , blower shutoff , white rodgers
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 05:00 PM
Painting white martinigirl Painting 3 04-26-2009 07:24 PM
Making a blower work with a White Rodgers 50A55-405 Controller gegnerx HVAC 3 01-13-2009 04:58 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 08:54 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
