Blower Runs For About A Minute Before The Heat Kicks In. Fills Rooms With Cold Air. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2013, 10:20 PM   #1
blower runs for about a minute before the heat kicks in. fills rooms with cold air.
my furnace is a Goodman gmp100-3 rev b. When my blower comes on it fills my house with cold air for about a minute, then i hear the burner kick on. It takes it even longer to heat my house since all the cold air was pushed in for a minute. I've made sure the thermostat is configured for gas furnace properly. I was hoping to get some help with this and will appreciate any tips and troubleshooting given. Thank you very much.
bahmtf is offline   Reply With Quote
Old 02-13-2013, 10:33 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by bahmtf View Post
When my blower comes... for about a minute, then i hear the burner kick on.
Has it always done this?
If a new problem... how old is the furnace?
Old 02-13-2013, 10:52 PM   #3
i just bought this house last may, but yes it's always done this since ive started running the heat last septemberish. I've had a big list of things to get done around here and i'm just getting around to this one. the furnace says 1993
Old 02-13-2013, 11:04 PM   #4
I had a similar issue. I have a gas furnace. I found that the thermostat (a Lowes bought Honneywell) was configured for an electric furnace.
For some reason, this caused the blower to kick on for about a minute before the burner.
Switching the thermostat to gas solved the problem.
On older thermostats, there are usually jumpers on the back for this. On new ones, there is generally a reset button, and then a series of "first time use" questions.
minza86 is offline   Reply With Quote
The Following User Says Thank You to minza86 For This Useful Post:
Marty S. (02-14-2013)
Old 02-13-2013, 11:07 PM   #5
MarginallyQualified
bought this house last may... it's always done this... furnace says 1993
Squeaky wheel's are like that.
The blower isn't supposed to start until the burner has been on for a while
(and it should stay on for a while after the burner goes off too).
It might just be the $5 sensor it might be the $200 board the sensor relates to. Either way...
Some manuals to read:
http://www.getbookee.org/goodman-gmp100-3-manual/
Old 02-14-2013, 04:53 AM   #6
Thermostat set up for electric heat is a very good possibility.
Old 02-14-2013, 05:03 AM   #7
An old Tradesmen
Rewards Points: 7,816
As others said, check thermostat configuration. Also, that model is known for popping its crimp rings. May want to watch if the flames start to jump around when the blower starts after you gt it to come on when it should.
Old 02-14-2013, 08:11 AM   #8
i should have put this in the first post. The thermostat is configured correctly for gas furnace, i've already gone through their support to make sure i wasn't missing anything. I'll start browsing through that manual thanks, any other thoughts?
Old 02-14-2013, 04:32 PM   #9
An old Tradesmen
Short in the thermostat wires. Lower aux limit tripped(look on blower housing).
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
blower runs, with no heat captjack HVAC 6 12-14-2010 02:15 PM
honeywell furnace/ac blower runs continuously not heat or ac grnded HVAC 1 05-30-2010 05:18 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
