Blower Running Constantly After Gas Cycle, Any Ideas? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 02:51 PM   #1
blower running constantly after gas cycle, Any Ideas?
Furnace cycles properly in heat pump mode. Also cycles fine in emegency heat mode with gas. But if left in heat mode, and outdoor temp drops to point where furnace calls for gas, everything cycles properly, heat pumps shuts off, gas kicks in, and once thermostat is satisfied and shuts system down, the blower stays on. It will actually stay on in between heating cycles. The only way to get it to shut off is to switch thermostat off, after a minute or so it will shut down. I turn back on and this will repeat again after gas heat is shut down. If anyone has any ideas, I would really appritiate it! Thanks! Oh by the way, furnace is Goodman, Heat pump is Rheem and Thermostat is Robertshaw.
rzrtrav is offline   Reply With Quote
Old 12-01-2010, 04:01 PM   #2
Rewards Points: 1,528
Is this a new problem or has it always done this?
bob22 is offline   Reply With Quote
Old 12-01-2010, 04:35 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
sounds like a possibly sticking relay
hvactech126 is offline   Reply With Quote
Old 12-01-2010, 06:44 PM   #4
It has been this way since the installation, (long story-bad deal!)
Old 12-01-2010, 07:42 PM   #5
HVAC / Plumbing
not wired correctly or bad relay
kenmac is offline   Reply With Quote
Old 12-01-2010, 07:49 PM   #6
I would guess not wired correctly, Is there a place to find a wiring diagram for this? And thanks for the info!
Old 12-01-2010, 07:54 PM   #7
HVAC / Plumbing
should be in the paper work with the unit/thermostat, etc
Old 12-01-2010, 07:57 PM   #8
I'll check it out and give it a shot, Thanks for your help.
blower keeps running dylansdadlv HVAC 0 11-30-2010 10:47 PM
Fan Blower Runs constantly on or Off !!! bluelatin HVAC 6 11-07-2009 10:27 AM
ejector pump running constantly??? streetwise83 Plumbing 1 09-13-2008 09:37 PM
furnace blower keeps running dmbrasket@hotmail.com HVAC 7 02-03-2008 04:57 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 08:03 AM
