-   -   blower running constantly after gas cycle, Any Ideas? (http://www.diychatroom.com/f17/blower-running-constantly-after-gas-cycle-any-ideas-88308/)
rzrtrav 12-01-2010 02:51 PM
Furnace cycles properly in heat pump mode. Also cycles fine in emegency heat mode with gas. But if left in heat mode, and outdoor temp drops to point where furnace calls for gas, everything cycles properly, heat pumps shuts off, gas kicks in, and once thermostat is satisfied and shuts system down, the blower stays on. It will actually stay on in between heating cycles. The only way to get it to shut off is to switch thermostat off, after a minute or so it will shut down. I turn back on and this will repeat again after gas heat is shut down. If anyone has any ideas, I would really appritiate it! Thanks! Oh by the way, furnace is Goodman, Heat pump is Rheem and Thermostat is Robertshaw.
bob22 12-01-2010 04:01 PM
Is this a new problem or has it always done this?
hvactech126 12-01-2010 04:35 PM
sounds like a possibly sticking relay
rzrtrav 12-01-2010 06:44 PM
It has been this way since the installation, (long story-bad deal!)
kenmac 12-01-2010 07:42 PM
not wired correctly or bad relay
rzrtrav 12-01-2010 07:49 PM
I would guess not wired correctly, Is there a place to find a wiring diagram for this? And thanks for the info!
kenmac 12-01-2010 07:54 PM
should be in the paper work with the unit/thermostat, etc
rzrtrav 12-01-2010 07:57 PM
I'll check it out and give it a shot, Thanks for your help.
