Blower Problem Keeprite Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 10:09 PM   #1
blower problem keeprite furnace
Model cgk075n06 the blower stays on all the time, if i power cycle the 120 volts it has about a 20 second delay then blower starts again the relay in the fan controll picks up. ive checked the limits they look good ive also tested them by unplugging a wire and the blower starts rite away no delay, so they seem good they also ring out on the meter. im thinking mabee the fan controll with the onboard relay or the fan relay. any ideas?
andrew5 is offline   Reply With Quote
Old 12-07-2010, 10:11 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
tstat in fan on? instead of auto
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-07-2010, 10:24 PM   #3
no if it were there would be no delay, i tested by junmping the green and red tstat wires at the furnace, it comes on rite away. there is a delay after a power cycle then the blower starts. if i unplug the 24 volt or one of the wires on the relay of the fan controll it shutts off.
This is not the fan relay im talking about its the relay on the fan controll 6wire unit.
Old 12-07-2010, 10:27 PM   #4
this seems to be the replacement for that fan controll although it doesent look quite the same the origional is made by heatcraft
http://americanhvacparts.com/Merchan...y_Code=fl-tdl3
mine has a potter brumfield relay built on 1 contact n/o i believe
Old 12-07-2010, 10:31 PM   #5
AKA HVACTECHFW
where is the 24v coming from?
IT IS WHAT IT IS
Old 12-07-2010, 10:46 PM   #6
24v comes from the transformer joines on the spade connector at the fan controll and then goes to the limit controll the relay onboard takes 120volts from the interlock switch through to the fan relay then to the blower motor. fan controll has 6 connections 2 are for the 120 volt and the other 4 are 24v, common , limit and valve.
Old 12-08-2010, 06:03 PM   #7
just to let u know ive replaced the fan controll timer, and this fixed my problem.
Old 12-22-2010, 07:16 PM   #8
I have the opposite problem.......my blower wont come on in automatic heat cycle......I replaced the fan control and the relay,,,,,,,,,we running the furnace fan on manual to get heat,,,,,,,,,,,,,cant figure out why it won,t kick in on auto
coyhunter is offline   Reply With Quote
Blower problem on American Standard Freedom 90 furnace ekimmo HVAC 8 08-27-2011 09:13 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Perplexing problem, Ruud furnace jbarker HVAC 43 01-20-2010 12:03 PM
Carrier Furnace Problem... cornation71 HVAC 3 12-10-2009 07:52 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
