Blower Not Turning Off - HVAC - DIY Chatroom Home Improvement Forum
Old 08-13-2011, 10:50 AM   #1
Rewards Points: 47
Blower not turning off
Got up this morning and my central air blower was running but the compressor was off. It seems to be switch related because the compressor did come back on after the temperature rose. Usually when I turn off the air from the thermostat the compressor and blow turn off. Now the compressor turns off only. What could be the problem?
tate16t is offline   Reply With Quote
Old 08-13-2011, 11:13 AM   #2
those are symptoms of an overheating compressor, but we will need more info. when the compressor turns off does the whole outside unit turn off? or just compressor?
try this: when the compressor turns on again, go to ur indoor unit and touch the thicker, insulated, copper line and if it is not cold to the touch, you may have lost a good amount of freon thus compressor overheats and shuts off.
Final Notice is offline   Reply With Quote
Old 08-13-2011, 11:15 AM   #3
BUT, before u do that, make sure ur fan setting is in "auto" on ur thermostat pls.
Old 08-13-2011, 11:18 AM   #4
Rewards Points: 47
Fan setting was not set to auto! Problem solved!
Thank you so much!
Old 08-13-2011, 12:35 PM   #5
haha nice! happens to the best of us
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Carrier Weathermaker 9200 - Blower not turning on. bvijay HVAC 7 08-15-2011 08:04 PM
Condenser and Blower not turning on nEmEsIs15dead HVAC 11 08-09-2010 10:56 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
carrier blower not turning off agartin HVAC 12 10-12-2008 12:42 PM
