Old 12-10-2009, 10:29 AM   #1
Blower not kicking in
Hello,
My blower is not kicking in.
I have a Lennox G4OUH-48B-090-11 S/N 5905K83441
What are the troubleshooting steps I need to take in order to define the problem?
Appalachian is offline   Reply With Quote
Old 12-10-2009, 11:20 AM   #2
The first step is to get the manual/wiring diagram. (maybe someone here can get you one).
The next step is to start tracing circuits starting with the control from the thermostst, low voltage, control board fuse and any safety lockouts.
If the above looks good, then move on to motor voltages and capacitor.
There are lethal voltages involved. If you're not comfortable then hire a pro.
hennyh is offline   Reply With Quote
Old 12-10-2009, 07:40 PM   #3
Need to check for 120 volts to the motor from the circuit board when the fan should be running. No voltage then you have a bad board, 120 volts present then you have a bad motor or capacitor.
I believe all those parts are still under warranty based on your serial number. Might be better to call the lennox dealer out to get the parts for free and pay the labor.
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 07:41 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Inside Blower motor keeps running crawlerchris HVAC 1 12-19-2009 09:01 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 05:00 PM
