The Blower On My Lennox Furnace Won't Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 04:23 PM   #1
Exclamation
The blower on my Lennox furnace won't shut off
We have a Lennox furnace, model # G16Q3-75-5. The blower will not shut off on it's own, even after the heat does. The only way to shut it off is to flip the switch at the furnace. what can we do to fix this?
kgduda is offline   Reply With Quote
Old 10-30-2010, 06:27 PM   #2
Odds are the heat exchanger is cracked which is not something you want to mess around with. Call a quality heating and air company to come check it out.
The Following User Says Thank You to Marty S. For This Useful Post:
kgduda (10-30-2010)
Old 10-30-2010, 06:31 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
has it done this since you turned on the furnace for this season or switched it from AC to heat (if applicable?). I would first check the thermostat to see if there is a setting for the fan of "automatic" and "on". It may be as simple as you flipped the switch unintentionally.
The Following User Says Thank You to nap For This Useful Post:
kgduda (10-30-2010)
Old 10-30-2010, 08:28 PM   #4
We had a new thermostat installed a few months ago, the blower worked fine with the A/C. We turned the heat on for the first time last night, and the blower would not shut off. The thermostat was on automatic, we double checked everything on the thermostat.
Old 10-30-2010, 08:36 PM   #5
GC/Master Plumber/Mech
Rewards Points: 560
Do what NAP said and double check that the thermostat fan selection is not set to on. If it is set on auto then the fan/limit switch is stuck.
Open the front of the furnace and look for a silver looking box about 5" long, 3" wide and 1 1/2" deep. If the cover is still on it you should see the words Honeywell. If the cover is missing then you will see a dial that kind'a looks like a clock but in degrees.
With the fan running lightly tap on the box and see if the fan stops running.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
kgduda (10-31-2010)
Old 10-30-2010, 09:04 PM   #6
nap
You talking to me?
nap's Avatar
but do not progress to the next typical nap step, which is; if a little tap doesn't work, continue to escalate the force until it either works, or you are very confident, that particular device will never work again.
kgduda (10-31-2010)
Old 10-31-2010, 12:21 PM   #7
The thermostat is set to automatic.
I have tried tapping on the box and yes it does stop the blower, problem is when the heat comes back on, the same thing happens again.
@Plumber101, just trying to fix a problem, not stupid.
The Following User Says Thank You to kgduda For This Useful Post:
emmett moore (10-01-2014)
Old 10-31-2010, 01:26 PM   #8
HVAC / Plumbing
Originally Posted by kgduda View Post
\@Plumber101, just trying to fix a problem, not stupid.
He didn't say you were stupid.. It may supprise you . But, some have found that the t. stat was switched to fan & not on auto. Had a lady call me last week. Her blower wouldn't turn off. She had the t.stat set to fan on
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
kgduda (10-31-2010)
Old 10-31-2010, 01:31 PM   #9
The limit is sticking and can be replaced. The G16's are getting old and are well known for cracked heat exchangers. That's why I recommend getting it checked out rather then just replacing parts.
kgduda (10-31-2010)
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Lennox ghr26 furnace problems wayfis HVAC 8 01-05-2010 05:51 PM
blower won't shut off on new gas furnace johnny67 HVAC 36 09-14-2009 09:23 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Furnace blower not working right. oiljumper HVAC 4 11-10-2008 10:22 PM
