-   -   Blower Motors and Fan Motors..... (http://www.diychatroom.com/f17/blower-motors-fan-motors-109988/)
JJboy 07-07-2011 08:43 PM
I wonder how far these small variations of the motors characteristics can influence the performance of the systems. Can someone explain this technically?
Do you use to cut the shaft when it is too long or not?
Blower #1: 115V, HP: 1/3, HZ:60, 1PH, RPM:1075,4 speed, AMP: 5.8
Blower #2: 115V, HP: 1/3, HZ: 60, 1PH RPM:1075,3 speed, AMP: 5.0 (replacement)
Fan #1: 208-230V, HP: 1/5, HZ: 60, 1PH, RPM:1075, AMP:1.5
Fan #2: 208-230V, HP: 1/4, HZ:60, 1PH, RPM;1075, AMP:1.7
(replacement)
Thank Y'all
beenthere 07-07-2011 09:46 PM
If the shaft is too long, you have to cut it, and a hack saw or sawzall works good for that.
On your blower choice, the replacement is a weaker motor, and won't move as much air, if the A/C is on high speed.
I try to stay closer on the fan motors. meaning I would use a 1/6 instead of a 1/4 HP motor generally. Your amp draw is very close tough, and probably won't give you a problem.
JJboy 07-07-2011 10:01 PM
Shaft is 2 inches long.
beenthere 07-08-2011 05:01 AM
2" doesn't sound like you have a motor with too long of a shaft.
