Blower Motors - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 06:39 PM   #1
Blower motors
My blower motor went out on my furnace. The old blower is a GE 1/2 hp model 5KCP39LG . Found two GE replacement blowers just not sure if they will work or not. Here are the model numbers HC41SE121A and 5KH39QN9401FT. The first one is a 1/3hp and the second is a 1/2hp. The original blower and the first new one are 1075 rpm the other new one is 1725 rpm. all are 60hz,115v, can anybody tell if the new ones will work and which is the best choice. The price is not that much to different either. Thanks .
Trainfan1 is offline   Reply With Quote
Old 11-19-2009, 12:58 AM   #2
Houston204's Avatar
Rewards Points: 556
GE Motor/Fan P918AS GE #5KCP39LG 1/2 HP 115V, 1075 RPM
That is a common motor. Why not get another 1/2 hp motor with matching specs?
Houston204 is offline   Reply With Quote
Old 11-19-2009, 06:15 AM   #3
Agreed. Doesn't have to be a GE but match the HP and rpm.
Old 03-20-2011, 02:44 PM   #4
I have the exact same motor and I am looking for a replacement, I did find a similar one new for $50 plus $17 shipping at the site below check it out.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=370492227213
shabtay is offline   Reply With Quote
Old 04-04-2011, 06:17 PM   #5
Blower motor
shabtay I believe this is a single speed motor right?
The 5KCP39LG same as mine is a 4 speed. I'm looking also but not sure if I can use a single speed on my furnace. Right?
gugie is offline   Reply With Quote
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 09:01 AM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Bad Blower on Woodstove Insert? Amycat HVAC 1 10-18-2009 07:45 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
