Blower Motor Won't Start - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2008, 09:23 AM   #1
Question
Blower Motor won't start
I have a Rudd furnace and a couple of weeks ago I changed the filters and cleaned the unit for the heating season. Everything seemed to work fine. Now the blower motor won't start. You can hear a slight hum when it should start and if I turn the fan by hand it takes right off. I have read here that it may be the capacitor. The question is, where is this item and can it be taken out and tested without removing the whole squirel cage? Thank you for any advice.
Vern
Verny is offline   Reply With Quote
Old 10-25-2008, 09:35 AM   #2
the Musigician
DangerMouse's Avatar
do you have access to maybe oil the spin shaft? if it takes off when you manually spin it, it may just be a little gunked up and in need of lube.
i just oiled a smaller blower yesterday that hummed and barely moved, and after a few spins by hand, it took off fine. i used sewing machine oil.
DM
Old 10-25-2008, 09:40 AM   #3
Lightbulb
Rudd reply
I'll go out to the garage in a few minutes and see what I can do. I think there is a place to oil the one side if the shaft but I'll look for a place on the other end also. thank you for such a quick rereply.
Vern
Old 10-25-2008, 04:12 PM   #4
Talking
Thank you so much. I went out and pulled the squirrel cage out as far as I could and cleaned it. I then used a few squirts of oil and so far so good. So far It is working as it should. Before I did this I turned the thermostat to fan only and it started right up. I was surprised to see how much crud was actually built up in there. Again, Thank you.
Vern
Old 10-25-2008, 04:27 PM   #5
the Musigician
no problem Vern..... glad to help!
never surprises me anymore...i've seen 'em pretty bad! heh heh
DM
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 02:03 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Armstrong Air - Circulation Blower Not Start Chris-MN HVAC 3 06-23-2008 05:04 PM
Blower Not Working sursedur HVAC 2 03-02-2008 09:39 PM
Furnace's blower is on all the time but gas burner does not start artgue HVAC 3 01-16-2008 06:46 PM
