Blower Motor Won't Run - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 07:49 PM   #16
Originally Posted by ldvoipeng View Post
after many hours of research
$203 worth, I think
It seems HCI, simply makes the controller boards?
I did locate the board, the entire controller board
HCI used Aromat Relay number JC2A JE-B-DC24V-H24V.
Aromat was bought out by Panasonic, and changed the number to JC2AF-DC24V-F. $7.66 at Mouser and Newark Electronics.
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Old 07-23-2010, 04:58 PM   #17
Just a further followup.
UPS 3 day shipping really means, 3 days from when they feel like it...
Finally the part came in, and a quick and simple 2 minute solder job, the blower motor still will not run. Further testing with the new relay, indicates the blower motor is in fact bad as well. Sighs. But a $100 repair bill for the relay and motor is still better then $400.
Again, Thank you all very much for all your help!
Best wishes.
Jared
ldvoipeng is offline   Reply With Quote
Old 07-24-2010, 06:51 PM   #18
Check the relay contacts on the old relay; it may be good as a spare.
If the old motor failed for external reasons you may still need to look for a root cause.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
