Blower Motor Whining - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2008, 09:31 PM   #1
Rewards Points: 20
Blower Whining –
I recently had a Rheem modulating furnace installed and two-zone heating/cooling. They also installed a 10 inch bypass damper for a 3.5 ton air conditioner.
I had a problem with my blower motor whining which was caused by too much backpressure in my duct work. The contractor is talking about two solutions.
  • 1. Increase my bypass damper to 12 inches.
  • 2. Reduce my blower speed.
Is one option preferred or does it not matter?
Thanks,
Jerry
Jerry8C is offline   Reply With Quote
Old 01-31-2008, 09:34 PM   #2
Union HVAC Tech.
Maybe he just needs to properly adjust the bypass damper. The bypass isn't just for a/c, it's there to regulate the amount of air going into the ducts when your only using one of the two zones.
The Veto propack, the Louis Viton of tool transportation.
bigMikeB is offline   Reply With Quote
Old 01-31-2008, 09:44 PM   #3
Rewards Points: 20
Mike -
Thanks for your return. Adjustment has been tried. As I understand it, a 10" bypass is used for a 3 ton AC, and a 12" bypass is used for a 4 ton AC.
I fall between the two.
Jerry
Old 01-31-2008, 09:57 PM   #4
Union HVAC Tech.
How long is the bypass ducting in total? Was it done in flex or hard pipe?
Old 02-01-2008, 11:20 AM   #5
Rewards Points: 20
It was done in hard pipe. It measures about 60 inches along the centerline of the pipe.
Jerry
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 06:41 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Looking for blower motor capacitor dditch66 HVAC 3 11-26-2007 07:35 PM
Blower control board mlmaher HVAC 1 11-24-2007 01:39 PM
Induction blower seal ktritz HVAC 4 03-05-2007 08:52 PM
