-   -   Blower Motor Whining (http://www.diychatroom.com/f17/blower-motor-whining-16464/)
Jerry8C 01-31-2008 10:31 PM
Blower Whining –
I recently had a Rheem modulating furnace installed and two-zone heating/cooling. They also installed a 10 inch bypass damper for a 3.5 ton air conditioner.
I had a problem with my blower motor whining which was caused by too much backpressure in my duct work. The contractor is talking about two solutions.
  • 1. Increase my bypass damper to 12 inches.
  • 2. Reduce my blower speed.
Is one option preferred or does it not matter?
Thanks,
Jerry
bigMikeB 01-31-2008 10:34 PM
Maybe he just needs to properly adjust the bypass damper. The bypass isn't just for a/c, it's there to regulate the amount of air going into the ducts when your only using one of the two zones.
Jerry8C 01-31-2008 10:44 PM
Mike -
Thanks for your return. Adjustment has been tried. As I understand it, a 10" bypass is used for a 3 ton AC, and a 12" bypass is used for a 4 ton AC.
I fall between the two.
Jerry
bigMikeB 01-31-2008 10:57 PM
How long is the bypass ducting in total? Was it done in flex or hard pipe?
Jerry8C 02-01-2008 12:20 PM
It was done in hard pipe. It measures about 60 inches along the centerline of the pipe.
Jerry
