Blower Motor Vibration - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 02:03 PM   #1
blower motor vibration
My Carrier 48gs started making a vibration/noise friday...I found these little half-round (shims??) laying in this opening on the side PLEASE HELP...THANKS Kenblower motor vibration-blower-002.jpg
kdsale is offline   Reply With Quote
Old 10-23-2011, 02:18 PM   #2
That looks like pieces of the blower wheel. Time for a new one.
Master of Cold is offline   Reply With Quote
Old 10-23-2011, 03:56 PM   #3
Thanks for the input...Any idea of cost $ ???
Old 10-23-2011, 04:27 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Under $60 for the part dependant upon unit.
http://www.pronto.com/user/search.do...254784863&site=
Doc Holliday is offline   Reply With Quote
Old 10-23-2011, 05:42 PM   #5
biggles's Avatar
that is the discharge of the ID motor for the heating which is the burner temp so it looks like the squirrel let go the motor might still run with a heat call but the air pressure switch might not make with the rounds gone...carrier might do a contact closure to proof ID fan be carefull... http://www.bestbuyheatingandaircondi...gory_Code=m-im might get away cheap with just a squirrel change out onto the exsisting motor
Old 10-23-2011, 06:59 PM   #6
HVAC Tech/ Browns Fan
You are better off buy the motor and wheel together. Getting that old wheel off that old motor is a ***** . You send more for repair but send less time working on it and save saying bad words.
Tator1076 is offline   Reply With Quote
Old 10-23-2011, 07:40 PM   #7
Hey you guys thanks for the help. Is changing that wheel something that an ordinary human being should attempt or not?
Old 10-23-2011, 07:55 PM   #8
You would have to buy a wheel puller. It costs about the same as a new motor.
Old 10-23-2011, 08:59 PM   #9
jkv
If you do get them wires hooked up the same way or you will be calling.
jkv is offline   Reply With Quote
Old 10-24-2011, 08:09 AM   #10
Rewards Points: 154
assembly
Ask for a new inducer assembly. Change the entire assembly. Its four or five bolts holding the entire thing in place. I would also check the heat exchanger if I were you. Its very common to find rusted heat exchangers when you find the inducer fan rusted. On these gas packs, condensate forms in the heat exchanger and inducer assembly during cooling cycles. If the heat exchanger is in bad shape, save your money and get a new unit!
Patrick Eubanks is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 04:48 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
