Blower Motor Upgrade - HVAC - DIY Chatroom Home Improvement Forum
Old 08-16-2013, 12:29 AM   #1
Rewards Points: 14
I recently had my blower motor in my 395CAV048091 Bryant furnace go bad. So I'm looking to replace it. These were my upgrade specs:
Old motor:
1/2hp 1075rpm 7.8amp motor
New motor:
1/2hp 1075rpm 6.5amp motor
New motor fit like a glove and was a cinch to install. Problems arose when it just couldn't push the amount of air we needed. There's condensation around basement vents and it's kind of noisy. My question is this:
1. How far can I upgrade my blower without damaging my system?
2. My furnace is rated for 10.4amps but I figure some of that has to go into the operation of the boards and such so how high can I go on amps?
3. Can I increase HP and if so, how much?
4. Will increasing RPMs make a big difference?
5. My board has 4 control spots for heat, cool, spare1, and spare2; I'm guessing putting the black "HI" speed wire on the cool jumper will dedicate the highest speed to the AC or is that handled by the COM port using the white wire?
I just want to upgrade if possible. Here are some items I'm looking at;
-----Variable HP motor
------3/4hp 9.1amp motor
-----3/4hp 9.5amp motor
I'm probably going to pony up and get a pro to install whatever I buy but I know I can get a better deal myself if I can just decipher my best move. I would appreciate any advice given.
Brian
briansterling is offline   Reply With Quote
Old 08-16-2013, 07:20 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
The amp draw on the new motor was too low. You can increase the HP to 3/4. DO NOT increase the rpm. You should have a pro install the new motor and check temp rise.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-17-2013, 06:11 AM   #3
An old Tradesmen
Rewards Points: 6,112
Its the amp draw rating that is important, not the printed HP rating. Different motor manufacturers use different standards to rate the HP of their motors.
You just need a motor to match the old motors ratings excluding the HP rating.
Old 08-17-2013, 09:00 AM   #4
Rewards Points: 2,630
I am not a pro, so I will leave this as a question for the HVAC pros, but it seems premature to replace the motor. I would think that you first want to check that the motor is drawing something close to full load amps, or at least is getting pretty hot. If its not, the problem is somewhere else. Specs say the furnace is 4 speeds. Is that motor actually turning at 1075 RPM?
SPS-1 is offline   Reply With Quote
Old 08-17-2013, 10:38 AM   #5
An old Tradesmen
His new motor isn't running at 1075 RPM, because its not the same actual horse power as the original motor. So it cant reach that speed and move the air that the old one did.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (08-17-2013)
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 09:06 AM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 05:48 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
