Blower Motor For Trane Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-15-2011, 02:43 PM   #1
Blower Motor for Trane Furnace
Hi
I need some information on my blower motor for a Trane Furnace. It is a model XL80 (TUD100B948A0) Does anyone happen to have access to a parts list for the Trane motor number for this model. I have been the Google route looking for the number. Trane does not make that number easy to find. I have replaced it before with a Grainger motor but it only lasted about 3 years. I wonder if I got the right horsepower or was that motor too cheap. Any help would be appreciated.
DocHallie is offline   Reply With Quote
Old 10-15-2011, 03:18 PM   #2
biggles's Avatar
Trane doesn't make motors or gas valves or relay boards its all other manufactrers Dayton motors are solid did you get it exact on that original first time change out... did it burn out or went out on bearings
Old 10-15-2011, 07:50 PM   #3
Rewards Points: 516
This can be a starting place but you'll need to know orig motor specs.
Check schematic on back of blower door?
http://www.fasco.com/prodcat.asp
diyorpay is offline   Reply With Quote
Old 10-19-2011, 04:31 PM   #4
Rewards Points: 77
We can cross Trane/AmStd, will advise
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
Old 10-19-2011, 04:34 PM   #5
Rewards Points: 77
1/2 up , 115v , 1375 rpm, psc , sleeve bearing , 48 frame
furnace blower cover whistling BlueBSH HVAC 4 02-17-2011 03:09 PM
How much power does a small furnace blower use? Red Squirrel HVAC 10 07-31-2009 09:03 PM
Need Suggestions for Furnace Blower Assembly LordX HVAC 10 02-25-2009 06:06 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
furnace blower keeps running dmbrasket@hotmail.com HVAC 7 02-03-2008 03:57 PM
