Blower Motor Shortcycles - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 03:38 PM   #1
blower motor shortcycles
It cuts on and off a lot
vtoler is offline   Reply With Quote
Old 11-18-2011, 03:43 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Regardless of which call it's on? Heating, cooling or fan on it does the same thing?
You have an electrical testing meter?
Doc Holliday is offline   Reply With Quote
Old 11-18-2011, 03:46 PM   #3
biggles's Avatar
if it happened in the cooling mode also or just FAN /ON at stat could be capacitor or if it's hot on the motor body on its way out.....motor is clean and the squirrels on the fan clean. if its happening in the heating cycle check the filter and tell us if the supply registers aren't as forceful as they use to be...
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 04:48 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
