Blower Motor Runs Constantly - HVAC - DIY Chatroom Home Improvement Forum
Old 07-21-2013, 05:11 PM   #1
j_sun's Avatar
Blower motor runs constantly
Hi,
I am selling my house and the buyer just had their inspector come through. I've just now noticed that the blower on my central air runs 24/7. The condenser only runs when the t-stat calls for cooling however. The switch is on auto and runs no matter what I do with the settings. I actually removed the t-stat from the wall and it still continues to run. My guessis that something was shunted to test the system during the inspection. I don't know much about hvac wiring so I'm not sure where to begin. Any help appreciated
Jason
j_sun is offline   Reply With Quote
Old 07-21-2013, 05:24 PM   #2
Rewards Points: 50
The last thing you want is a DIY repair on a home sale especially since the inspector has already pointed out. Help your self and your sale call a tech out. This is something, at least in Texas, that you now have to disclose as a known issue.
Jmo
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 07-21-2013, 06:23 PM   #3
An old Tradesmen
Rewards Points: 6,548
If your furnace is oil. Does it fan a white button on the fan limit switch that may have been pushed in and left in. If so, pull it out.
The Following 3 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (07-21-2013), FClef (07-21-2013), j_sun (07-21-2013)
Old 07-21-2013, 06:33 PM   #4
FClef's Avatar
Rewards Points: 160
I would contact the inspector and tell them what is happening and ask what they did that may have caused it. If it is the sellers inspector that did it then he should fix it.
FClef is offline   Reply With Quote
Old 07-21-2013, 06:39 PM   #5
Plumber_Michael's Avatar
It's either a stuck fan switch or a relay, depending on the unit. Being an hvac technician myself though, I'd have it serviced instead of trying to DIY (sadly). It doesn't take much to short something out or blow the transformer. That being said, if you can read a wiring diagram and have a basic working knowledge of electricity (like unplugging the furnace or switching off the breaker first), you can probably find and replace the bad component with little trouble.
Plumber_Michael is offline   Reply With Quote
Old 07-21-2013, 06:41 PM   #6
j_sun's Avatar
That was it! Thanks!
Old 07-21-2013, 07:44 PM   #7
An old Tradesmen
Your welcome.
We all like when its something simple.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (07-21-2013), digitalplumber (07-21-2013)
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Trane xe 90 furnace blower running constantly. sshaneparsons HVAC 4 12-08-2011 11:50 PM
Blower fan runs constantly epowerfan HVAC 65 12-06-2011 07:57 AM
need help/advice with a blower motor that runs constantly in a old bryant GetYourShineBox HVAC 0 07-27-2010 07:29 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 10:08 PM
